Well I went out and got a BeoPlay S8 to try and simplify my set up (removing a preamp/DAC) however unless I am doing something wrong the volume control does nothing!
I did go through the remote IR set up as written in the manual (ending on solid white indication). However the only command that it seems to actually work is mute. Volume up or most importantly down seem to have zero affect and everything plays at full volume. I tried two different remotes and many button combinations.
It is supposed to accept volume up, down and mute which is totally fine but I cannot seem to get it to work.
Now I am connecting via rj45 > PL a Bl2 & BL8000s if that makes a difference. Triggering seems working however this thing is useless now.
What am I doing wrong?
