BeoPlay M5 ?
I heard that M5 eventually will get the same sound mood settings as Beolit 17.
Yes :( Maybe a bad product. It happens sometimes. Not a big issue I will bring it back but if someone from B&O reads this thread : please, let us lower the bass....
Still on the lookout, and hopefully for the next SW update:
First priority: Would be very happy if I could pair the Essence remote again with the M5...
Second priority: Sound settings...
Alexa could connect to the M5.
Since my BS 9000 is connected with a BLGW to NL i can control music with Alexa in my main room.
On my my last party it was impressing all the guests :-)
Ralf
After the end of March SW update, it looks B&O added again the possibility to pair a remote.
But as the app says its experimental:
"Please be aware that the remote support is currently experimental and you may experience issues especially in environments with lots of wireless systems and wireless alarms. If you experience issues you may need to reboot your product."
Anyone have tried to pair an Essence remote?
Would be nice to add an Essence remote. I find it a bit fiddly to e.g "double tap" , and also switching  on and of laying in bed 🙂
I'm a bit puzzled that there continues to be no in-app equalization for this device (aside from the wall/corner switch). The bass really is too strong - I hope B&O reads these forums!
I have   pair an Essence remote to  my Beoplay M5.
It works like clockwork. I am really pleased  🙂😁🙂
How do you switch source on an Essence remote?
Double tap somewhere?
