Hi all,
I have noticed a strange behaviour with my Beoplay M3 recently since it was moved to the kitchen.. I have created a listening mode (EQ) to add more treble, saved it and selected in the B&O app, but when the speaker’s unplugged for a while and subsequently plugged back, in the EQ appears to have been reset back to ‘optimal’ (the default) but the app still shows the saved listening mode as applied. It’s definitely not on the saved profile as I can select Optimal with no difference to the sound, then select my saved profile and the treble is restored.
I would be grateful if another M3 owner could test this same scenario to see if theirs behaves the same before I contact B&O support. I’m running firmware version 1.11.45906 on the M3.
Update - just discovered that my new M5 exhibits this issue too :(
Many thanks. Rob.
