AnalogPlanet wrote:
...and btw, aptx means nothing to iPhone people, only to Android folks. Just fyi.
That's interesting and thank you for that info - I get that aptx is a higher bitrate for bluetooth wireless connectivity, but am unsure how that benefits Android OS phones and not IOS phones. I assume apple doesn't support it, and hence its plain vanilla Bluetooh 4.2 for them?
On the other hand, I would also assume that as you can use an cable if the power of the battery runs out, that plugging a cable in (with the battery charged and bluetooth switched off on your iDevice or H9 which I also assume is possible), would essentially mean that all audio is transmitted by the cable and not bluetooth, hence giving higher audio quality anyway than either Bluetooth 4.2 or aptx which use significant compression algorithms to keep bandwidth down and transmission distance longer.
Of course if you're listening to streaming music over the internet at say 256 AAC as per apple music, one may not hear much to an advantage, but as I have an iPhone 7 plus full of Classical and Jazz recorded in ALAC, I would hope using an audio cable rather than bluetooth for static listening, would provide an audible advantage - at least in theory.
Having recently purchased a pair of B&O E8 2.0's with which I'm very happy (apart from some yet to be resolved hassles as with all in-ears re getting the perfect ear tip seal) I have been interested in a pair of H9/9i's for some time - usually when an update has been released is the best time to buy to get the latest specs and features etc.
So I may well dive in and add a pair to my modest collection - initial reports sound very positive.
Thanks again for your info - much appreciated
Cheers
John
