Beoplay H8
Just ordred a pair :)
/Uldall
/Uldall
Me too:-)
TWG wrote:
I'm curious to know how the aluminium touch controls will work under certain circumstances like cold or humid weather.
The controls use pressure, not capacitance so can be used even with gloves.
I have also ordered but my retailer will get them 18th febuary. I´m quite sure I can't wait that long.
OK the proof is in the pudding and I will be ear testing ASAP as I appreciate sound is subjective,  personally I prefer the looks of the H8's compared to the Zik 2.0 so 1 - 0 on the 1st count.
Parrot Zik 2.0 B&O Play H8
Price UK £299.99 £399
Weight 270g 255g
Dimensions 175 x 202 x 39.3mm 180 x 190 x 40mm
Battery Li-Ion 830mAh Li-Ion 800 mAh
Charge time 2.30hrs 3hrs
18hrs in travel mode 16hrs with Bluetooth
Standby 8 days no info
Bluetooth 3.00 4.00
AD2P AVRCP HFP PBAP NFC aptX AAC HSP HFP A2DP AVRCP
Frequency 20Hz - 20kHz 20Hz - 20kHz
Speakers neodymium 40 mm Dynamic 40mm
Crutchfield in the US has them in stock. I just ordered my pair.
does anyone know if you can easily replace the battery and how many charge cycles it can take ?
16:00
https://www.youtube.com/watch?v=OiTJgUIRqsI&spfreload=10
Ola Hansen wrote:
that's clever
mine was delivered today, next monday I have my  first flight with it.
Its not coming with a proper case, just a sack, the controls do work but taking some getting used to, for example I can only switch noise canceling off using my thumb, not my pointer finger.
Need to play with it some more ..... will report back next week how trip went ....
