BeoPlay H5 does not have multi-point connection
Unlike majority of recent Bluetooth headphones and earpieces, I discovered with great disappointment  that the BeoPlay H5 does not have multi-point connection. -- In other words does not allow to have two phones connected at the same time.
This is a pity... As more and more of us are using two devices at a time.
Is this feature addressable via the next software update?
Perhaps I am not understanding.
I thought my H5 remembered multiple pairings.
I will check tonight.
I am not sure my ears could cope with two iPhones talking at the same time.
multi-point connection is not multi-pairing.
Multi-point allows to have two phones connected at the same time, so if you receive a call on either one you can take the call.
OK
Then I believe you are unfortunately correct
