Beoplay H5 & Running
Hi all,
I just can't get any luck keeping these tightly in my ears.  I'm not a big guy, and I'm using the large earbuds, but they slide out when I get sweaty and run.
Anyone have a 3rd party ear lock or other ideas?  Any chance the rubber tips work better?
Thanks.
ekohn00 wrote:
Hi all,
Thanks.
Hi!
You have to put the cable over your ears. There is a small statement for it in the manual. During a run I've been using them like that and they are amazing. On a 11k run I don't have to touch them to keep them in.
Good luck!
Roy.
I didn't see that in the manual.....  But I can see that helping, it probably keeps them from weighing down and eventually out.  I assume over the ear and behind your neck still?
Thanks.
Yes! Exactly like that.
Roy.
