Beoplay EQ
The Beta programme for the App is a bit annoying. Sometimes the public release is newer than what is released on the beta programme. Even if fixes are deemed ready for direct release without the need for beta test, they should feed the same release to the beta programme. It's annoying that you have to monitor which of the two paths is the newest.
I had now used my EQs almost daily since I had them delivered early November last year.
I use them mainly during dog walks, commuting and occasionally at my home office.
Had them replaced under warranty quite early since one earbud was loosing power much faster than the other. That process was very swift with B&O support. Since then there has been no problems.
In-ear headphones may not be for everyone, but I appreciate wearing something more discrete when Im out and about. Having tested many of the supplied eartips I landed with the comply foam ones.
Sound is so pleasant and detailed in these earbuds. Great soundstage and really nice bass. Way better than my old Beoplay E8 2.0, and also better than my AirPods Pros. I mostly listen to some of the mixes from Radio Paradise, using the ALAC setting in their app.
What I miss (and I have told B&O through their support) is the ability to skip to next track and to activate SIRI.
Maybe this has been shared before, but
