Beoplay EQ
I've been using them on a daily basis since the 20th of August and I'm pretty much satisfied indeed.
I moved from the AirPod pro olso even if I bought the E8 3rd, but since I experienced quite a lot of connection issue I was happily using the AirPods (well this is disappointing thou...)
Fit is almost perfect and sound quality is awesome as usual. I'm very impressed by the ANC. When walking with it on (and music on as well) I sometimes experienced the full isolation and traffic buzz simply disappears.
Materials are very nice (both tactile feeling and weight) and battery last very long.
So far I'm very satisfied, I don't remember B&O has ever manufactured such a good earbuds set.
If you're considering to buy, go for it.
GLOP
I went for the Comply Tsx-200 Comfort Plus ear tips link - not sponsored ;)
even if I bought the small they are still slightly larger than my ear fit, but still very soft and easely to adapt to my inner ear shape.
Alternativelly go for the
Is it correct that the EQ lacks a "skip forward" gesture?
This is my most frequently used feature as I mostly listen to machine generated playlists from Spotify/Deezer, and they don't always get it right. This would stop me from upgrading my e8 gen 3s... then again, if I ever start traveling again, the ANC could tempt me even without the skip forward (since my current H3 ANCs don't skip forward either... or maybe they do, but I only press the buttons for ANC, no ANC, transparency).
I do confirm. The HQ lack of the very nice gestures present on the E8 whatever gen. (skip or voice assistant activation)
I guess (pretty much indeed) it could be implemented by OTA update in the future. Figer crossed.
GLOP
I personally do not have that issue since I simply sync purchased and downloaded tracks to my iPhone. I have only used a few gestures in my previous E8 earphones anyway. But Skip forward is indeed a sensible gesture to have. I’d imagine it might come as a software update. Or can anyone more knowledgeable tell if the number of gestures or combinations have been exhausted with the EQ? Have they had to make a compromise?
In any case I think the EQ is so far still the best upgrade to the E8 series, and all in all a worthy upgrade.
Just got an email from B&O with an offer to "Upgrade your earphones to Beoplay EQ and enjoy 20% off".
Could be done online or at a dealer showing the email.
I ordered and put my E8 2.0 for sale.
Yes, got a similar one about upgrading to the HX. I am happy with my H95s though, so no reason to «upgrade». I suppose they send these emails based on order history, in which I’ve indeed had all the H-series over the years.
It's based on the headphones/earphones linked to the account via the app :)
