Hello. Interested in Beoplay E8 3 rd gen one bud is master and second slave or both buds master? In my Beoplay app, the charge level of the right bud after use shows less than that of the left( L90% R70 %). Before use after charging, the charge level is the same ( 100 %).
Beoplay E8 3rd gen battery level
Dear Amigo799,
Beoplay E8 3rd Gen has a master bud (Right) and a slave bud (Left).
Since I have been using this product just for 1 month, I haven't experienced this issue.
How do you check the battery level for each of the bud?
I believe it is a master / slave arrangement. That's one of the difference with the EQ. You can use either one by itself. With the e8, you can only use the right by itself.
