BeoPlay Connection Hub vs Beosound Core
DinoD wrote:
All the above speakers are in different rooms, what I have done was have a datecated CAT cable run done down  to the basement. So the rooms would be free of wires and anything that would have to connect to the speakers.
Rooms
1. BL3500
2. BL4000 Pair
3. BL8000 Pair & BL12
4. BL8000 Pair
5  BL5 Pair
Would getting a beolink gateway help with my set up?
They are not connect thru master link, can you explain it please ??
In your earlier post you mentioned a ‘beovision’.
Which one and how is this connected to the ‘cat cables’, that you mention?
How is the connector - could you post a picture of it?
It’s a BV7-55
with BL 12-2, 2, 3 & 7.6
its has one Ethernet plug, not sure what I could do with that
There is an ethernet port in the BV7-55 - but that is only used to update the bluray player in the tv....and not for any daily use.
The MasterLink connection there? Isn’t that use to connect to the devices in the other rooms?
By the way  - now I remember, that you are the guy with this question/problem (which seems to be solved now).
/forum/general-discussion-and-questions/thoughts-on-my-speaker-set-up-and-recommendation-changes#post-2113437
