@AnalogPlanet
I'm having the same problem.
Is there anything I can do to help solving the issue?
@AnalogPlanet
Engineers are now looking into my logs, hopefully will be able to figure out the pattern.
Also, I have shared your nick in case they would need more different logs to check.
Genuine attention to this issue and sense of urgency I feel are making me confident the solution will be found as soon as realistically possible and released via FW update.
As long as I see someone is very seriously trying to fix it I don't mind being a bit patient.
I am also experiencing the same issue.
Any news on a fix?
Nothing yet - probably (hopefully?) in the same week as Moment's update which is supposedly scheduled for W26.
Hi AP What does all this mean? week 20, week 26? W26 of what? the financial year? the release? :-)
If you are in contact with the Engineers would you mind telling them that in the next firmware release they need to fix the SSL 3.0 issue that many security companies have alerted the user base to as being weak. My network monitoring system is in constant alarm, advising me the A9 is a scurity weak point.
I don't think it's a huge deal on a private network but something they could fix if another firmware update is due.
For reference:
http://googleonlinesecurity.blogspot.co.uk/2014/10/this-poodle-bites-exploiting-ssl-30.html
My interpretation was week 26 (w20 originally) of the calendar year. :D That is week of June 22nd.
With the following disclaimer: as everyone was preannounceing multiroom and other features being rolled out via FW update for Moment, Essence and A9 I took liberty to assume A9 SW team wanted to incorporate also this fix into it.
Now I did not comment on that with a B&O person I was in contact with, as I know every vendor tries to fix an issue asap and would gladly release FW update only for it if they were able to do it much earlier than the "big" multiroom update. Or maybe I'm just naive. :)
Done, thanks for the input - let's hope engineers will be able to add this one to the next FW update.
Great news: the cause of an issue when A9 "freezes" with both LEDs blinking was isolated and fix has been found. FW update release as anticipated mid-June.
Seems this is coming together with other FW updates and new features for A9, Essence and Moment. Anyway: yay! :)
Not so great news. :/
Happened again, this time by streaming via AirPlay. Oh goodness, will it ever be fixed?
