Greetings,
Any updates on this?
Greetings,
Greetings,
I have still not moved yet so not had a chance to set this up how I want. I will probably move in 3 weeks time, as soon as I have done the full setup ill post on here with an update.
I have finally moved house and am now setting this up again,
Doing it the way you suggested works fine however I need help with the subwoofer as that does not work at all
The sub is plugged into the yamaha and switched on but it seems the pre amp is not sending signal out to the sub
Deleted - double posting
A pity that we only can see parts of the pictures.
Sorry about that, resized the photos in original post
Greetings,
What happens when playing music, what colour is displayed on the sub itself? Try logging into the app and check sub settings of that yamaha? give a shot and share steos you've taken when connecting the sub. screenshots will do. if you can give me a call on skype and happy to assist although you previously insisted you want to use this platform for comms.
If the sub is not playing, there might be an issue with the sub or the subout of the yamaha itself. did you plug any other sub on the yamaha? did you try he pv1d on a different system to test if does work?
attach video if you may
good luck.
Setup is finished fully and it sounds perfect.
Thanks all for your help, small video demo can be viewed
I had this set up with a Sony TV and a pair of A9s. I used the line in (stereo) jacks on the TV and A9s. Like someone said, use an RCA Splitter. I went direct from TV to A9s. No delays and sounded great. TV remote or Apple TV remote controlled volume. There was no delays…
for music, I used Apple Music or YouTube from the TV. The Apple TV/ remote was all I needed for everything.
overall, it was great for music, not so much for movies.
