Beoplay A9 Mk1 - Using two speakers as stereo sound for TV/PS5
Hi there.
I recently got 2 x Beoplay A9's at a really good price and they sound awesome individually.
I want to set them up as stereo speakers for the TV and if possible my PlayStation 5 as well. I know I can use the line in ports to make this happen but what device do I use?
I am thinking it will be something like below
TV/Playstation ---> Amplifier with 2x Line out ports ---> Beoplay A9
But is this correct? Beoplay A9 has a built in amp right? so would that damage them to plug an additional Amp into them?
I am a beginner at these things so I have no idea, any suggestions would be much appreciated.
You need an amp that has pre outs for this to work I believe.
....and you will most likely run into some sound delay problems.
Can you give me a bit more info on this or do you know of any devices that will work for this that you can link as an example?
Is pre out the technical term?
Sorry for all the questions, Like I said I am new to this
Hard to say, because the devices (the preamps) may vary.
I can’t give you any advice on which one will do the best job - maybe someone else.
You’ll need one with pre out connections.
If you have one with line outs, they normally will output at a fixed level. These are made to connect to an amplifier. This might work with the A9’s....but in that case you’d have to control the volume there - on both A9’s simultaniously (which in real life will not be possible).
There are some just stereo, however most people use a multichannel receiver with preout connections.
You will have to deal with the question of how to control the volume as well.
Most tv’s nowadays only have digital outputs (most seen are the optical outs).
The problem there is that these are fixed/at a fixed output - means you can not use the volume control of the tv.
(Some people alternatively use the headphone output - these in general are of lower quality. I would not recomment that).
With a preamp you will be able to control the volume output from that device - some preamps have a remote control, the multi channel receivers certainly have.
In that case you would have to leave the volume controls of your two A9’s untouched........after you have level matched them to each other.
Also consider, that if you place the two A9’s (as L and R) relatively far from another, it will be hard to sit in the sweetspot - that is where the phantom center is created.
Without a dedicated center channel (for watching tv, movies, games) and only with a stereo setup, the phantom center tends to move away from the place where the screen is, when you move.......and spoken words will be less audible.
Not saying that you should not do what you have planned - just saying, that it might not be as easy as expected.
Thanks for the detailed explanation and advice, it is much appreciated.
I have done a bit of homework and it looks like something like link could work. The fact its bluetooth also means I could connect phones to the speakers over bluetooth through the pre amp.
I just have 1 question on the setup, would it be ok to use a cable splitter adaptor on the "AUX" Line out to each of the speakers? the back of the device is below
Duplicate post...
Thanks so much for the information.
I have ordered the new pre amp (cancelled the old one) and have also purchased the y splitters with cables. ill set it up as soon as it arrives and let you know the outcome.
Thanks again
only a pleasure.. i'm anxiously waiting on the outcome. if you could drop me a dm we can communicate via skype. i'm keen on this
Would be a shame to limit the experience to a Skype conversation.
I guess other beoworlders could be interested in the result.....that is what the forum is about.
