Beoplay A9 - how to distinguish MK1 vs. MK2
I consider to buy a second hand A9 if I can find a MK2, as I would use the multiroom feature. It seems sellers usually do not know whether they have the MK1 or MK2 version. I also found it difficult to find information about the differences when I searched Google and this forum.
Is there an easy way I can distinguish between the two by asking sellers for known functionality, ports or labels on the hardware? For example if only MK2 features Spotify or have a new input port?
The mk2 has Bluetooth.
Great, thanks! Seems there are actually no Mk2s out there after all.. 😉
The MKII hasn't been out that long so not that surprised many aren't available yet.
Dave.
Hi!
Does anyone know if type 2890 is MK1 or MK2?
Best regards
Ola
