BeoPlay A9 and netgear dg834g wireless router
I have a Beoplay A9 speaker and am connecting it to a Netgear DG834G Router which is about 5 years old.  Every time i put in my WEP key in to the set-up software and click on apply the A9 trys to connect but the orange flashing light appears.  When I take of the security password then the unit works fine on airplay anyone else had the same problem or could help me out.
Also I want to buy the Beovision 11 TV but am not sure if the CI slot will support Conax CAM cards does anyone have the answer for this one?
Time to upgrade your router and move beyond web.
The Beo 6 wireless security will not even handle wep.
You need a new router.  Make sure you pick one that works well with Airplay and not just the least expensive one!
Thanks for the tip.  Before going out and buying a new router I done a firmware update on my router and got it all up and running with no drop outs and a strong signal up to the third floor.  Thanks Guys
