Beoplay A9 Airplay unstable
Hi guys,
I just bought a BeoPlay A9. I connected it to my network with a 300 Mbps connection and relatively good router. I use my ipad to stream music from. I think my Airplay is very unstable. Sometimes it can not find the A9 and often when I change song Airplay drops out. Whereupon I'll have to press Airplay again. Do you guys have the same problem and a possible solution to it?
/kamuk000
AirPlay does seem to have its limitations. I have similar issues in that sometimes AirPlay just doesn't pick up my many B&O devices such as Essence, A8, A9, two playmakers and only picks up one or both of my ATV's. If I 'renew lease' under my wifi settings that makes it spring into action.
Check the quality of signal to your A9 via you Beosetup.app. I think others have suggested making a static link to it?
Dave.
Try a 5Ghz Wifi network. I also had a very unstable situation and after this change it is by far better.
I always switch off my WiFi when I go to bed (as I don't like signals messing my body). By doing this and switching it on the next day, I find Airplay is pretty reliable whereas when I used to leave the router on all of the time, it was not stable on the A8.  Never problems on the ATV just the B&O A8.
I thought I was the only one that did this! 😳
As I've said previously, with the wifi coming through our household electricity cables to a sender, I sometimes have to unplug the sender and plug it in again for AirPlay to work and have all devices found by AirPlay. Same principal as turning wifi off and on again I suppose.
Dave.
Thanks guys.
It looks like the 5Ghz did the work. My devices can always find the A9 - so thats great. Thx :)
But but but
(Almost) every time i change a song through youtube or another music app, I have to press the Airplay button and find the A9.
Have you guys a solution to this issues? Maybe make A9 a default airplay player?
Thanks for reply.
How do I find a IP address? Just the same as my PC?
Install Fing on your iDevice
Cecilb wrote:
Hi guys, I have endless trouble streaming via airplay to A9. It plays fine for 10 - 20 mins then starts breaking up...
See above? And please don't suggest your own post as the answer :)
