Beoplay A9 (4Th generation)
Does anyone know if it is possible to combine  the Beoplay A9 (4Th gen) with the older Beolab 14 (2. Satellites speakers and the base unit) so they play as one unit?
You can via with Multiroom if you connect the Beolab 14s to a Core.
Thanks frederik - do u think that the A9 Google assist would then also activate the Beolab 14’s? Or would I have to turn them in separately… my goal would be to join the A9 (with Google assist) and the beolab 14’s and voice control it as a single integrated system by voice command.
Yes, you can setup Core as a Chromecast unit in the Google Home app.
Tnx- bought a core and it’s working a treat 👍😊😊
