Beoplay A6 frequently crashing after latest software updates
my Beoplay A6 started crashing pretty much nightly and I have to unplug it to get it back to normal. I think this came in with the software update 2 releases back. It was initially much worse but the current software seems to just let it happen overnight.
Is this just mine or do others have the problem too?
Cheers
JK
I use my A6 daily and I do not have this issue.
Normal audio, tuneIn and music via netlink works fine.
Chromecast stopped working unfortunately.
I am not using chromecast but noted that after some updates I had to accept the user conditions again. If you go into the app under your content ....
Cheers
JK
No such problems.
The critical events log is empty since the latest update in April. So that is a good thing.
