Martin wrote:
I have two A6s. One of them updated yesterday to 1.20 software. The other will not update to new software for some reason. It still has 1.19 and says that software is up to date. If I use BeoTool it says there is new software for the A6. I have tried to reset to factory but it did not help. After factory reset I can not login to Deezer or tunein either. Does someone know What to do or What is wrong with my A6?
best regards
Beovision Eclipse 65 with floorstand (from STB Brackets), Beolab 5 front (sw 3.30a), Beolab 3 rear, 2xBeoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K
Did you reset to factory on the app or press the button underneath?
I had this with my BS1 at one point and i pressed the button down the bottom (the one with the little cog shape next to it) and reset it that way.
Only one time have i had to remove it from my beoapp and then press the button and then reconfigure it all together. Then it said it had an update.
