I have a white one on the way to match my new kitchen!
Snap!
Oh I don't thing they're that fragile!!
Ty hitting it with a 20lbs sledge.
Gladly!!😜
Why all the hate?
Oh it's not the A3, it's the attachment!!😂
Snap!
Gladly!!😜
Why all the hate?
Thank you so very much for your helpful, intelligent advice
Beonet. The a3 has no audio in connection so I don't think that Bluetooth thing will work. I have just bought an a3 half price I white. It's worth£225 but I don't think it was ever worth £445 same amount as an I pad. I am most happy with it, I keep my old ipad2 inside it . It would look crap if you didn't have the iPad inside it. If you wanted to listen to music from a distance keeping hold of your I pad why not try a beosound8 with that little Bluetooth thing that will work perfect? Also I have just set up my apple to properly so now I can acces all of my iTunes on my tv which is connected to my beosound9000 beolab 8000. Works a treat and sounds perfect. All in all the a3 is a great bit of kit, I use mine all the time it's good for FaceTime, Skype, watching tv, you tube and listening to music all hands free for a change.
i also put mine photo mode so it's like a digital photo frame
david
Do you think this would work with the A3?
Will most probably work.
The A3 is about to be discontinued. It was confirmed by my dealer today. They are selling the A3 at 1999 DKK istead of 3999 DKK 🙂
Mods, etc...
To the clown (I know who you are) who keeps "unverifying" this thread...
Why? Unless you have some information that counters this -please stop.
May I remind YOU that a lot of time, money, and effort went into implementing the new software on BeoWorld with this feature.
It is there to help make the site better.
Let us use it so -or not at all.
Thanks.
Hi beonet. I didn't realise that it connected to the 30pin connector. Are you planning to hide it behind the speaker cloth? If you are. If you give me the measurements I will check it will fit if you like?
david
Is it simply that simple?
