Beoplay A2 charger
I've lost my Beoplay A2 charger and want to order another one, what size do I need please?
Can you not just use a regular 12v charger? I generally do. With the A1, I use my Macbook charger!
I don't think there is an alternative to the one we order from B&O which is ridiculously expensive. If someone has found a cheaper none B&O version I would be interested to know....
Hi, same question here, lost my Beoplay A2 charger (NOT the USB version). Ordered other 15A/3V charger at webshop, but all the included charging pins do not match the A2 or lead to charging. Anybody got a tip where I can find a charger which works, apart from B&O? Thanks..
Ah yes... Login to view imageLol...everybody has a "snakes wedding" in a box somewhere....cables cables cables
