For the record, here is the legend of
Is it possible that your speaker has been used and paired before?
Is it possible
The speaker has never been used before, package was sealed
i do hear the beep when it starts up
when i then puch the bluetooth button the status light turns red and it starts uo again
then go 's to white again
seems like it dous a reset that was my first tought but i do not touch the on off button only bluetooth button
the speeaker is for a promotion from b&o itself and is 100% genuin
Connect it to a computer and run the update program.
Right:
A bit off-topic, but fits in well here.
Has anyone tried to put the A1 (one or even two) in retail/store mode?
I could imagine, that it/they this way could be used as speakers connected to an audiosystem or even to a tv.
Anyone, who knows more???
I guess running in store mode may require POS software ...?
Bang & OlufsenEnabling the retail mode in our B&O PLAY products enhances the consumer experience. This ensures that the B&O PLAY POS speakers are always powered on, the speakers are set to maximum volume and have disabled Bluetooth.
THE SPECIFIC ADVNTAGES OF THE RETAIL MODE
The retail mode will have the following advantages on the speaker:
• If the speaker is powered via the POS display, the speaker will not turn off/go into idle mode. The speaker will automatically turn off if power is disconnected to the display. When the power is reconnected, the speaker will automatically turn on.
• The Bluetooth function will be disabled so that the speaker always works optimal with the music from the display
• All buttons on the speaker are disabled. This ensures that the speaker will always work optimal with the display
• The speaker will be set at maximum volume to ensure the most impressive demo experience. The user can adjust volume on the display.
And what is POS software?
Not knowing exactly what is meant, when using this mode in the store, my guess is that the speakers are connected to a (central) sound source.
And that this is used to control the volume of the device/the A1.
Just wondering if that could be (mis-)used for connecting to an audiosystem at home....in order to control the volume from there.
If noone here knows more, I guess I’ll have to ask my dealer next time I’ll be there.
As far as I understand it a POS terminal could be a computer or tablet, such as an iPad.
Why not just try it?
Have a look here:
I guess there's a secret button pressing procedure to enable/disable POS mode on the speaker?
Sounds very interesting and hopefully somebody here can solve the riddle for us.
