Hi
I am thiinking of replacing my PC and the new one will come with Windows 7. Will this operating system be compatible with Beomedia1?
Hi
Hi
Did it work with vista - if it did I would think Win7 would be OK. Win 7 also has an XP compatibility mode.
No I have never used it with Vista, only with XP
I've installed Beoplayer on my laptop with W7.
I had some difficulties to locate the Beomedia. It didn't connect.
But after renaming your networklocation from "Home" (that's the type of network W7 asks you) to "Company".
Make sure that your workgroup names on both the Beomedia and your computer are the same.
Only then after installing the beoplayer(or beoport) software, it will find the Beomedia.
Thanks, that's a relief
Hello,
I do understand that Beomedia should work on windows 7
The following is taken from www.bangolufsen.com FAQ for Beomedia1. Note even if it's below is referring to Beoport and Beoplayer, those are the softwares used by Beomedia. Latest version is 5.04.00, possible to be downloaded at the very same site.
Hope it helps
/cjocc
Is the BeoPlayer and BeoPort software Windows Vista/Windows 7 compatible (used by Beomedia1)? |
| Answer | |
Yes, BeoPlayer and BeoPort are compatible with:
BeoPlayer is also compatible with 64-bit versions of Windows Vista, Windows 7 and Windows XP. Please note that only the newest version of BeoPlayer is Windows Vista, Windows 7 compatible. |
Don't know anything about Beomedia but I'm particularly impressed with Win 7 - if your machine is running XP or Vista, and is capable of running Win7 I would definitely upgrade.
I've upgraded my laptop several month's ago and I totally agree 🤒
Windows 7 for instance is faster then Vista, a big relief. From XP to W7 takes some time to get used, but no regrets so far.
