I'd love to get hold of a copy of the beomedia software !
It would be a great product if it were to run on an up to date hardware platform.
Oh I suppose that would be Beo master 5 then ?
Beomedia one was build on low spec / low power hardware with minimal cooling to keep the noise down
It was also built using Windows XP embeded that is a bit of a pig to work with as it only has the bits installed that the software / hardware needs to use it's now more commonly called WEPOS (windows embedded point of sale) because it's used mainly in the electronic cash tills. it's designed to have an application built around it and then not be modified.
Back to my first point if I had a copy of the software - a ghost image of a system would be OK i will get it working on a high spec unit.
