BeoMedia and Link Room TV's
Yes you can get up picture on Link-Tv but not pilot it with Beo4
So you can use N.Radio and N.Music only
I have an early model BeoVision 5 which I have recently connected via a SCART to BeoMedia, and call up via V.AUX on my remote. I was under the impression that I would be able to view PHOTO and WEB on my link room television in addition to listening to N.RADIO. However the installer informed me that I would only be able to access N.MUSIC in my linked rooms. Is this correct?Thanking you in anticipation.
Hi Stuartross
I have the following setup:
BV7-40 connected to Beomedia 1 via DVI as well as the composite video cable and a BV6-26 as a link TV and am able to use N.Music, N Radio, Photo and web on the link TV. The key to getting the picture on the link TV was the composite cableand using "L PC" on the beo4 to call it up
My view is that it should work in your setup as well, can you give us a full view of your setup in terms of equipment and connections
Will also respond to your PM with my phone number in case you want to give me a call to talk it through
Steve
There are two challenges here:
- Your BeoVision must be able to distribute the BeoMedia video signal. As mentioned above, a 7-40 can re-route the DVI-input to the RF OUT - and handle the "PC" command (=the BeoVision has control over the BeoMedia 1, not a separate IR eye connected directly to the BeoMedia 1)
- The link BeoVision must be able to handle the PC command (L-PC). The 6-26 can.
The PC command was added with the last SW update just before the DVI-version of the BV 5 hit the market.
Roger
You do not have to change the resolution of the BeoMedia - the RF modulator takes care of that. This was, and perhaps still is, an issue when it comes to the distribution of "future" tv-signals over BeoLink: HD DVD, Blue Ray and HDTV will have to be distributed with the original numbers of lines intact - at some point in the not to distant future. This change in video distribution will allow for proper quality from the BeoMedia 1 as well.
Roger
Option1 as Roger describe is only available if you connect BM1 to AV4 with Composite
I am pretty sure that BV7 can not route DVI to RF
DVI is not enough to use L-PC
So:
BM1 VGA-----BV7 DVI
BM1 composite------BV7 AV4 Composite
Use both of this
But this works only on BV5 HD version
Hello,
We've had a nightmare of a situation with our BeoMedia...
Initially we tried to get BeoMedia connected to our BV6 22, but the DVI was different so it was using a SCART connection which wasn't great plus the BV6 only has two SCART sockets and had to lose out DVD1. We purchased a new BV7 32 and all is OK BUT the link BeoMedia (via BV6) has a hum/buzz.
Out intention was to use the BV6 22 as a PC monitor, but have been unable to get our PC laptops to connect to BV6 using DVI cable (even though the laptop sees the BV6 in it's setup). Out local B&O dealer (Cambridge in UK) is still investigating...
Thanks,
Davidw
Hi David
BV6-22 only has DVI - D input (Digital only), so problem is with your Graphic card:
1: can your graphic card put out Digital DVI? If yes then find out if it set to DVI-D! If yes then download the leasts Driver for your card!
Still no luck? Then you have to find a new graphic card, not all cards are compatible with BV6-22
BTW Welcome to beoworld 🤒
