beologisch:
I can agree with you on this, but not to my liking though : I've had a pair of Pentavoxes [after I tried a pair of Redline 140] attached to my MB7000 and they sounded fine, but that all changed when I tried a pair of Pentalabs III with my BM7000. I kept them, sold my Pentavoxes promptly and never regretted it; aspecially when playing loud.................π
Has anyone ever experimented on how much of this is due to the tiny DIN connectors and the typically really thin cable you can comfortably attach to them? I usually laugh at high-end cable voodoo, but it's easy to believe that there are audible effects when you think of the currents that flow in the passive speaker cables...
-mika
Don't worry about it - even lowly 1.0mm2 wire has only 0.019 Ohms/metre resistance. A 2 metre speaker cable will only be 0.076 Ohms!
