Thank you all for your quick Responses.
I am almost sure the System got not damaged on moving, since it was a moving one Floor up the same house. My dad also said that the System was working just fine after the move and it only stopped working after it was reinstalled in a new shelf. So Í am almost sure it must be a Setup error as I know my dad is very careful with this stuff and that the headphone jack is corroded in exactly this Moment would be a very big coincident.
To answer the additional questions:
1) Yes the Speakers work fine on on and off, and mute and turn from red to green and also on unplugging them while on there is a clear Signal from the cable.
2) Yes, I have checked that (if it is the Switch on the back of the BL8000
3) The CD Switches on but as soon as I press Play it Switches off, the main cabinet stays on CD, just the CD cabinet Switches off. I also tried with the Vinyl and tape Player and Radio. They all work but no Sound is to get our off the Player.
Everything seams to work fine except the Sound. I have two remotes and all System reacts to each other perfectly.
One Thing I wanted to add. My dad had removed the AUX IN/OUT plastic connector on the back because he thought it was a broken cable. I red that can be an issue with the Sound. However, I have put this back and it is still connecting two pin together each and one pin is alone (I hope this is correct).
Thanks for all your support, I live in Northern Italy and it is impossible to get this System serviced here, I tried...
So I really appreciate all your help!
here the Pictures with the setup
link
link
