Hi there fellow B&O enthusiasts!
Recently I've been having troubles with my Beomaster 6500 which worked perfectly fine, however, not anymore. The reason why I started working on it was that I wanted to connect an older Beogram (1600) which wasn't RIAA amplified and I magically found the original spare part for sale nearby (part: 8001245 which was new in box)!
So during the weekend I opened up my Beomaster and carefully removed the logic board which needed the installation and installed the part into the logic board just like the steps that were mentioned in the manual (can provide this if needed). The manual said I had to cut two jumpers and one pin in the phono powerlink socket which I also did according to plan.
After the installation of my RIAA pre-amp I decided to spin my vinyls again and play it on my restored Beovox cx100 loudspeakers, but I was struck with disappointment. I couldn't hear any sounds coming out, not even from the radio or so. The only moments I hear sound coming out is when I turn up the volume to the max and it is very inaudible. This also counts for using the headphone socket. Later on I decided to try a pair of active Beolab loudspeakers which gave sound, but the next day it was gone? The first thing I found online was that maybe the relay switch had oxidized over time and made poor contacts, so decided to spray it with contact spray and give it a shot, unfortunately still no sound. Second attempt was re-soldering a loose connector on the logic board that gave some static sounds when I was troubleshooting, unfortunately still not the answer to my problem.
Long story short: my pretty and fully functional Beomaster 6500 does not give any audio signals to my Din/Powerlink/headphone sockets anymore after I installed the RIAA kit.
I hope any of you might know where to look for and can help me out!
Thanks in advance,
Alain 🙂
