hi just brought a beomaster 6000 early type .the black perspex is badley scratched .I would like to know the best way to deal with this problem ?and if so would I lose the film that covers the perspex ? thanks
beomaster 6000
Hi,Trouble is, there is indeed a foil on the surface which is impossible to polish.Remove that foil first (I use strong adhesive tape) and polish – yes it’s a destructive process.However, you will never get the original feel and texture.
hi jacques can the black perspex display be taken off the unit and replayed ? regards shaun
