On my Beomaster 5500 the words 'Timer Off' are constantly lit. Is it possible to 'turn them off' please?😮
Cheers
Paul
Cheers
Paul
To start or stop TIMER OFF you press the right side of the front (POWER) and while pressing it press the left side (STEP) quickly, then the TIMER OFF should stop. This function is for cutting the sound in mainroom while you have a TIMER set for a LINK-room.
Hope that helps
Jesper
Sweden
Cheers Jesper, just goes to show that you really do learn something new every day!
Paul
