beomaster 5000 turns on with volume at maximum
I ask for help. My beomaster 5000 turns on with the volume at maximum, I changed the battery and the diode seems good but if I memorize when I turn it on again the audio is always at maximum
Just to check the obvious, are you using the MCP5000 to memorize? When you have chosen the desire volume did you press "Store", and then when a "P" blinks did you press "Sound"?
Also - replace capacitors in the processor module.
