I’m holding onto the old motherboard just in case.
Beomaster 5 repair
The radio stations need one or two days 2 pop up after a software rebuild.
Really? Well that’s something to look forward to. I suspect though it won’t because it says that the unit isn’t registered at the bottom of the n.radio screen.
The software rebuild has made the beomaster stable now though.
Oops - looks like I managed to mix up the BIOS chips - changing the chips DOES work!
If I remember well, you have to reprogram the BIOS with the Epia tool, so then you will have the B&O startup logo when booting.
I didn’t need to do that, the logo came up straight away.
Hi, is of these boards still available? I might need one as my BM stopped working. Only blinking red light :-(
Yes, I still have some of the 1500 boards available. As I have 4 beomaster 5s, I couldn’t take the risk! Are you able to handle the SPDIF connector removal and connection?
