Before I wall mount my 4500 system I'm going to renew all the double sided tape under the glass panel. I can get the glass panel off, however, understand that there's a couple of screws holding the frame onto the switch panel.
How do I get to these underside of the switch panel to get to these screws and reinstall. Would rather ask first than launch in !
Also, is there a recommended thickness for the double sided tape ? got some 3m stuff, but it's very thin.
Unfortunately I can't access the service manual as there's a problem upgrading my subscription.
Many thanks.
