BeoMaster 3500 weird radio problem
Hi.
I have just fitted a BeoMaster 3500 in the kitchen for my wife to listen to Radio 4 and for me to listen to CDs or my iPod.
Everything was going swimmingly until I tried to use the radio.
Basically, the CD player works perfectly and the iPod works via one of the other AUX sockets but although I can tune and store FM stations I  cant hear anything.
If I turn the volume up on full I can hear the radio station very feintly in the background but othewise I get nothing through the speakers.
Anyone have any ideas?
Do you have any kind of FM antenna connected? B&O tuners are pretty good, but usually won't play anything without an antenna of sorts. Often a simple piece of wire stuck in the connector will be enough!
Of course, the tuner might have a fault but check this first.
Yes...there is an antenna connected....the tuner seems to be finding all the usual frequencies without any problem!
