Beomaster 3000 PROBLEMS HELP PLEASE!!!!!
Hi there, with just 24 hrs till my father comes over for the "Yesteryear evening" that I  have been planning for so long... I find that today its all gone a bit "limp" on me....
Here are the Symptoms:-
Place 33/45 on turntable
press play
Needle & other arm come across
Needle goes down before the begining of the Album
Then proceeds to gently limp across the vinyl untill the inner circle
Then lifts & Returns.
Checked that there are NO scratches on 'Old Frank' ( Sinatra that is)...
Now sweatin it!!
HELP !!!!!!
Could you please verify exactly what equipment you have? Is it a
My Beogram 5005 did exactly this on my Beosystem 5000.
It seems to be that if the Beocord was plugged into the master, but not into the mains, then the gram would drag itself over the LP, then return to rest.
Luckilly this was before I bought a cartridge without knackered suspension.
So its worth checking all other datalinked equipment has a mains supply!
Are you not talking about a Beocenter 3000?
Edit: Oops there is no Beocenter 3000!!
Hi there, its as follows:
3361048
 oooops sorrry thats the serial number.. its a beogram 3000
 It is plugged into the mains off its own power cord + linked to my Beomaster 3000.
Does this help?
