beomaster 3000
hi i will be having a beomaster 3000 soon isit poissable to connect beovox 3800 speakers and beovox 1001 speakers to it and is there any cable i can get to connect my ipod to the amplifyer ? and if so where would i connect it on the beomaster 3000 ? i cant seen to find a aux input for it ?
and which beomaster is better out of the 3000 and thr 4000 ?
thanks
Hi Steve,
Since you mention the 3000 and 4000 together, I'm going to assume you are talking of the 70s slider units.
You can connect an iPod two different ways to the 3000, by RCA or by DIN. I plug my iPod through the TAPE connection.
The appropriate cable can be found at our site sponsor, Steve at Sounds Heavenly.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
hi yea sorry im talking about the 70s ones i just woundered what one was the best ? and if theres a massive differece between them
Spec's are on site for both in the products section - link & link
Chris.
The 4000 is better - and the 4400 the best of all. All are very good though. Watch for transformer hum in them though.
