Beomaster 2000
Hi - can anyone please tell me if a Beogram CD4500 is compatible with a Beomaster 2000 amp - I'm sort of assuming it is but would be grateful if someone could confirm for me!!  Thank you 😁
Hi and welcome to Beoworld!
I guess you have the Beomaster 2000 type 291X produced from 1983 to 1987 and not the Beomaster 2000 Type 2801 (1974 - 1978).
The answer is yes and no:
yes, you can connect the CD4500, but you won't have remote control. There are three ways to connect:
- with a din to phono adapter, connected to the phono input (tape 2)
- direct connection to the din input (tape1) but you have to remove pin 6 and 7 of your CD Din plug
-  connection via tape/cd adapter (available from B&O
