Beomaster 1700 or 2000
Dillen wrote:
The Beomaster 1700 may not be a technical wonder but it is a unique design and most tractor belt
problems can be solved.
Reproduction rubber clutch "washers" are available.
Martin, have the washers got to do with selection buttons not working. Mine don't click into place! Just pop back up as soon as I let go!
No, that's usually the power switch not releasing completely, thereby not allowing other switches to latch in.
It will need a good internal cleaning of dust and oxidation to move freely again. Fiddly job but possible.
Worn rubber washers will cause slippage within the clutch mechanism.
Thanks for the tip Martin!
Hi Martin,
I can lay my hands on a BM 2000-2801, seems to be a kind if "luxury teak finish", 100% working condition; they ask
50 Euro's. Is this real value for this type of machine?
regards,
Aad
