Beolit12 battery replacement / upgrade?
Thermal sensor these are 2 black cables, I have no idea where the blue and green cables will connect.
I think that green and yellow are the sensors for equal charging.
And blue and two black are thermal sensors.
This is the only one I could find from the past.
Are the batteries connected to each other in the middle?
No - they are not.
I have some battery issues with my Beolit 12. Any tips on how to disassembly the beolit’s battery module?
cheers,
...and also. I can’t find any cells at Amazon that seem to fit.
Any suggestions?
You should to upgrade this thing
Hello everyone,
I have upgraded my battery (Beolit 12) with 3.5Ah cells and it works just fine. It requires certain skill and knowledge, but I am willing to advise anyone interested.
Would it be possible to build the Beolit 15/17 battery module into the Beolit 12?
This module can be bought.
