Andreas wrote:
I am afraid stereo pairing in the Beolit series is only possible via Bluetooth. This means that connecting a 3.5mm jack to one of your speakers will simply disable the wireless connection and you will not able to pair them.
But you can simply buy 2 RCA to 3.5mm jack cables to connect each channel from the phono preamp to your Beolits.
But wouldn’t you then get the left channel respectively the right channel to each of the Beolit.....when the input there expects a stereo/L-R input.
I wonder how that would sound - did you try it out?
Otherweise, I am with Leo....get a set of e.g. the BL4000’s and it will work.
If you get a Beomaster (or a Beocenter) plus a beoremote as a volume controlling preamp it wil work wonders :-)
