Beolit 17 is official
No, sound wasn't important. I am happy with the 15. Only reason to upgrade would be the added functionality. And as I suspected, it seems unreliable. And you can only choose one of the options at a time for the single button. Why not add 4 new buttons?
Leogoeswild,
I am new to the Beolit family so I am happy to hear that you are pleased with the 15.   I have two 15's (recently purchased) and I could not be happier.
I am now in the market for a Beolit.
Should I rather go for a 15 than the 17 as you have mentioned it is unreliable?
Beoplay app works as a remote when paired.
I solved the alarm mystery after a while of experimenting with various sequences - no thanks at all to manuals or B&O "support".
1. Connect your phone and speaker by BT
2. Open your music source app, for me Spotify. Start your playlist and pause or stop by sleep timer; keep the app open
3. Open the B&O App and program the alarm. Make sure One Touch Function is set to Alarm
4. On the speaker, press the One Touch Button to initiate
I've verified this a few days now. This sequence works for me. Skip #2 if you're using the built in alarm tone. Important thing I found was to press the one touch button to turn it on after the programming step on the app.
Had my unit over a year now. Love it.
