Beolit 15 and Beomusic App
elephant wrote:
Isn't that option the other way around ?
ie B&O to publish the NL protocol, and the OEM DACs to comply ?
Or did you want a B&O black box with a digital output to USB or TOS connection ?
Yes you are wright
That option could be done in several ways
  => having  B&O publishing it's NLprotocol
 => having a B&O black box with usb connection , but in this case the Dac drivers shopuld be compatible with the b&O Black box that leads to have either a Microsoft  or Mac Os inside the box
=> A coaxial or toslink connection could also do the job , but my priority order would be Usb 1st, Coaxial 2nd, toslink 3rd because in this order you find more quality /options in terms of Bit and Sampling frequencies
I was in an official B&O store in Denmark two weeks ago with my Beolit 15, the guy in the store told me, that soon there'll be an update, so you could connect more Beolits.
Edit: Already mentioned somewhere else on this forum, sorry.
It will possible to connect 2x BL15 for a stereo sound system only.
I repeat, the platform used in BL 15 is not compatible with Multiroom System.
@BeoBoy 68
       Do you know what is missing inside the BL 15 in order to be Multiroom compatible ?
There is only a bluetooth chipset from CSR inside.
B&Oยดs Multiroom protocol a.k.a. NetworkLink is based on TCP/IP and would therefore require at least a wifi or eth phy chipset...
thanks for this important information
I suspect that B&O will announce a new Beolit in the coming monthes with multi room functionnality.
If I am right I wonder if B&O has a deep obsolence strategy or if they have a 6 months roadmap vision for their products
Facel wrote:
@BeoBoy 68
Hi Facel
BeoMotion reply to you faster ๐Ÿ˜
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
