BeoLit 12 is in the shops! Initial impressions?
I have used mine for a week now and I have some trouble with wifi....it drops the connection all the time
My router(netgearWNDR3700v2) is standing 5 meters away!!
I think it has bad wifi range!!
Whatever the quality of the router, 5m is within every routers capability... Strange, can you lend another router and try?
mr_anders_son wrote:
I have used mine for a week now and I have some trouble with wifi....it drops the connection all the time My router(netgearWNDR3700v2) is standing 5 meters away!! I think it has bad wifi range!!
Try a different wi-fi channel? I get dropouts with all sorts of equipment, including an Airport Express. It happens. I played around with various channels (after leaving the router on "automatic") and since manually selecting channel 4, never had a single dropout (as no-one ever seems to use channel 4, so there are no conflicting channels).
I change from my Dovado(once per day I had to restart it)but same issue....I shall reset BL12 and see if it helps
I have reset it but no different
Ok anyone else had bad connection to Beolit 12?
My router stands aprox 5 meters away and beolit setup says it has less reception and when I put it beside my router it says good!
And I have tested 2 different routers.....
going back to my dealer....
I have reset it but no different Ok anyone else had bad connection to Beolit 12? My router stands aprox 5 meters away and beolit setup says it has less reception and when I put it beside my router it says good! And I have tested 2 different routers..... going back to my dealer....
The only thing to do... I hope you get it sorted soon.
Does anybody know when BeoLit will be available on BeoPlay's webstore? The press release said february, but half of the month is already gone and there's nothing new on the official website..Danish speed again? 😁
Now!..but only UK, Denmark, France, Germany and Netherlands
Slt Christophe J ai eu le mien deja 1mois now je l  ai achete a B O  Ternes  a Paris  super son j en suis  content . A plus.
Ehh what are you saying?????
