I recently purchased a Beolit 12, and while I'm pleased with it's performance, it seems to go into standby mode after about 15mins of non-play even when connected to a power source. This is rather irritating, because it means attending the machine to switch it on, and then wait for it to acquire the wi-fi signal. Not ideal if you are in bed on a cold morning
Beolit 12 and standby
Really?
I'm not familiar with the Beolit, haven't even seen it, should keep the wifi connection if connected to mains IMHO.
I like my Beolit 12 also and am very pleased. I noticed that in standby after about 15 minutes, wifi does disconnect. I assumed it was in the setup somewhere and for me it was acceptable. I usually charge my iPhone and iPad using the Beolit 12 which makes it a docking station. No problems in docking mode. However I am going to review the instructions. There are times when I also prefer Beolit 12 not disconnect from wifi.
Thanks! I'll try it as soon as I get a chance
I just got a Beolit 12 and so far am very pleased with it. However I have the same problem. Software is version 1.02.12 which seems to be the latest. It does go into sleep mode when not used, and simply disappears from the WiFi. Unlike the PlayMaker (which I have connected with a set of Beolab 6000) it cannot wake from WiFi signals. DOes anyone have any info to share, any advanced settings I don't know of. I'm quite unhappy about this. Thanks.
I got my Beolit 12 a few weeks ago. Updated it to latest software/firmware.
It is connected to a powersource and works fine. But when I return home the following happens:
-I swipe upwards on the iPhone and choose "Beolit 12" as airplay speaker
-It gets marked with a "V", then nothing happens for a while
-The "V" shows up next to "iPhone"
I can play through my other airplay devices without problems when returning home.
Anybody experienced this and knows a fix, or should I try to return it to the store?
With bluetooth 4.0 no wifi dropouts
