Beolink5000 - Beovision7000 - motorised stand= not working together...
Beolink 5000 or 7000 remote are not able to send a STAND command.
You need a Beo4 for that.
My recent Beovision 7 can perfectly turn the stand using the picture key from my Beolink 5000, 7000 or 1000.
But it is worth borrowing a Beo4 to test before looking at the stand itself.
Thanks for the help at first! (This is a excellent forum, btw.:))
I checked out my MX7000:
Type 33/86, SW 1.6 (I'm not sure in the "6" in the software version, the sticker is not the best in that point... Manufacturing year should be 1994)
For controll, i have two possibility:
Beolink 5000 (Type 1620, don't see any software versions there...)
Beolink 7000 (Type 1540, S/W1.3)
Is there something what i must check on the motorised stand? Has the stand something inside besides the motor? Is there also different versions?
Thanks in adv.!!!
Charles
Thanks Phil!
Me was told, the BL7000 can send a "Stand" command.
The BL5000 is just mentioned in the manual from the Television (MX7000), that both remote controlls are able to controll the full functions on this television, so the BL1000 and the BL5000 too.
I don't wish to give up, it must work!:)
Thanks!
Charles
Try and borrow a Beo4 that can send the Stand command. Test it on your TV.
if the TV turns, then it you can try and see on the remote side.
If the TV doesn't then look on the stand side.
p.
Thanks Phil!
So you mean, that the problem can't be with the television itself, not with the SW version, etc.?
Ok., i will try it, and let you know about the progress!
Thanks!
Charles
Edit: sorry, I didn't notice that you already posted the software version, and that should be OK - I'll leave the next paragraph here for reference to other readers, though... Please, skip to the next point 🙂
AFAIK it depends on the software version of the television. You can check it with menu-0-0-go if you have a Beo 4 (dunno how to do that with other remotes) or simply take a look at the type sticker in the rear. If it says "SW 3.1", the picture command will not operate the stand, not with any remote. If it's 1.something, it should work. There are two different manuals for the MX6000/7000 - the first one talks about Beolink 1000 and the later one about Beo 4.
Furthermore, go to the setup menu of your tv. Do you see "stand" as the last selection down under "sockets"? If not, the TV and the stand are not communicating.
I have a MX6000 sw 3.1, a Beolink 1000, a BL7000 and a Beo 4, and the only one of those that is able to rotate the stand is the Beo 4...
Regarding the stands - if you can plug it in, it should work. MX8000 (and MX4002, I think) had a different stand, but the plug is also different.
Zugn:
Could be the TV as well unfortunately. But do not panic yet!
I don't panic, but i see the trouble now with the software refresh in the future...:-)))))
