Beolink5000 - Beovision7000 - motorised stand= not working together...
Hello!
I have this combination with the Beovision 7000 and the Beolink 5000, and when i connect the 4 pin plug from the motorised stand to the Beovision 7000, then it not works.
Manual says, i must press the picture key at once, then it must work with the < and >. But it doesn't.:( Immediatelly after pressing the picture key, the "brilliance" is in the corner. This word should be there only if i press the picture key twice!
Is there something what i must set in the Beovision, before connect such a device?
 Many thanks in advance for any help!
Charles
You need to connect the stand to the TV before you connect the TV to the mains power supply & power up or the stand won't be recognised.
Unplug everything & start again plugging the stand cable into the TV first.
Chris.
Thank you Chris!
I have try it, but no success.:(
After i unplug everything, i have wait about 30 seconds to ensure, that all the capacitors in the circuits are empty.
Maybe i give a try to wait more after disconnect from the main supply.
Thanks: Charles
Beovision 7 or 7000 or MX7000?
Beovision MX7000!
Sorry, i wasn't perfect by the beginning!
I try out with longer power off period (totally disconnected from main supply), but still no function.
I don't have here the Beolink 1000.
Only Beolink 5000 and Beolink 7000 is at home, but I will charge now the 7000, maybe that works!
Thanks for the help!!!
Charles
It appears the problem is with the stand or the TV, not with the remote, unfortunately.
Oh Dear...
Can someone help me out with the 4 pin plug connection diagram?
I have a multimeter here, can measure the voltage what is coming out from the TV.
Maybe i can put a separate power supply to let work alone the stand too...
The only problem what i see now is, that (when i believe the remote control manual) when i press only once the picture key, then i shouldn't see the "brilliance" word on the screen. This must be happen only, if the picture button is pressed twice!
Or i misunderstand something?
Thanks:Charles
btw., the Beolink 7000 don't wish to give "free" the picture button on the panel, that means, that it don't light.
grrrrr...
I still stand (pardon the pun...) with my original idea that your set has the later version software just like my MX6000 does, and the stand simply cannot be operated using the "picture" key. In that case, the remote command "picture" is simply for adjusting the picture, and that's why it goes to brilliance at once. You have to go through the setup menu ("stand" is there, is it?) or use a remote with the "stand" command.
