Hello!
I have this combination with the Beovision 7000 and the Beolink 5000, and when i connect the 4 pin plug from the motorised stand to the Beovision 7000, then it not works.
Manual says, i must press the picture key at once, then it must work with the < and >. But it doesn't.:( Immediatelly after pressing the picture key, the "brilliance" is in the corner. This word should be there only if i press the picture key twice!
Is there something what i must set in the Beovision, before connect such a device?
Many thanks in advance for any help!
Charles
