Beolink Wireless 1 Timer Function
I finally contacted customer service in Struer myself, and they suggested that I check to see if my three Beolink Wireless 1 units all had the latest software version. Unfortunately, there is no way for the end user to check which software version was installed at the factory, as it is not listed on the units or shipping cartons; it can only be determined by a serviceman using the software installation tool.
I had the local B&O service tech check the software version the next time he came around for the latest round of software upgrades for my BS3, BV7, and BV8. Sure enough, all three of my wireless units had the old original software version, even though they were purchased quite recently. Apparently BOA is shipping old product from their warehouse; neither they nor the dealer are bothering to upgrade the units before delivery.
The good news is that, after upgrading all three BL Wireless 1 units, rebooting, and resyncing them, the timer function now works on the two Beolink Wireless 1 receiver units, as well as on a BS3500 that is ML hard-wired to the main system. An unexpected bonus is that it is not necessary to activate the timer on the Beosystem 3 menu in order to have it function on the link systems. The timer on-off menu setting on the BS3 affects only the main room speakers connected to the BS3; the link systems use the timers programmed in the main system, but are activated independently from the main system, either manually by touching the remote IR sensor timer button or else via the appropriate Beo4 commands. None of this is explained in the manuals with any of the components, by the way.
The bad news is that the software upgrades for the BS3, BV7, & BV8 still didn't remedy most of the problems in those units. So what else is new?
Thanks for your quick answer. The timer play function doesn't seem to interest a lot of people. I asked my B&O local dealer this afternoon and he called B&O France technical service. I've got 5 wireless (one transmitting, two connected to 2 beolab 3500, one to beolab 4000 and the last to a beolink passive and passive speakers. The main system is a BV7 connected to a BS 3000 and to a BV avant via masterlink.
They suggested first to switch off the wireless connected to the 2 beolab 3500 and to try if it worked.
It doesn't work with the beolab 4000 or with the passive.
The second suggestion was after the first test, to upgrade the soft. I'll do that like you made.
What I don't know is if type of connection between the wireless and the speaker is important (I have powerlink full wired between wireless and speakers or beolink passive and not masterlink)
