Looking back on that the BW1 has been available for quite a while now; does anyone have information when and what kind of modifations has been made to this unit since released?
Beolink Wireless 1 Hardware/Specification updates?
The Type # for all BeoLink wireless from 2006 till now is 1780, indicating, there are no
hardware changes, it's just the SW changed August 2007 from Mk1 >> Mk2
It should be possible to update all units to current SW.
SW update 2.1 is allowing ML-Mode in the Linkroom.
SW 2.1 has been implemented August-2007 to all BeoLink Wireless 1 with Serial# higher
than 19956171.
Excellent - Thanks for prompt answer!
How do you update the software of the Wireless? And once again, I do not have the privilege of going to "my dealer" since there isn't one any longer.
Best Regards!
Update via PC & "Service Tool" avilable to B&O dealers / B&O service (centers) / B&O installers.
IMPORTANT: You'll also have to update all your BeoLink wireless to the same SW version,
otherwise connecting is not possible.
Okay, thank you!
It is becoming quite hard to retain a loyal B&O fan since the dealer network is almost non-existent and B&O doesn't offer any online/DIY support for simple tasks as software updates.
Regards
since the dealer network is almost non-existent ...
Come on - if you pack the Wireless 1 units properly it will be easy to ship them
to the next dealer / service center for an update - using a parcel service like UPS / TNT / DHL / ...
I agree. Kit I bought a few years ago - I have been palmed off onto some 3rd party 'expert' company to maintain - this is really not what I expected from B&O. They need to get national service centres up and running as the dealer support isn't what it was.
That might be true. However the point is - as Frog also commented - the service provided for B&O products is also here outsourced to a 3rd party. To be more specific a 3rd party which doesn't answer the phone nor reply your emails (not the best way to build up an entrusted customer service relationship).
I still consider a software update (among few other B&O related things) being something to be distributed via the internet in the 21st century.
Regards
Sorry to hear that, but my experience with my local 3rd party B&O service center in the Vienna region is
completely different! They answer the phone, reply mails and are doing a good job.
